300E coolant sensor problem?
Old May 1, 2004 | 01:05 PM
Ron in SC's Avatar
99 ML 320, 97 Porsche 993 C2S, 92 300E
Question 300E coolant sensor problem?
The low coolant light stays on with plenty of coolant in reservior. No corrsion around pins, I pretty much got them clean.
Tested Ohms on sensor and with coolant hot it was about 400 ohm. What should it be? I would like to confirm that sensor and not connector is the problem before I change.
Old May 1, 2004 | 02:37 PM
Daniyar79's Avatar
1992 Mercedes 300E
I don't know what it should be, but I can tell you for sure that cleaning it doesn't help. I cleaned mine and it still was on all the time, so I just replaced it. No problems any more. Another guy about a month or so ago posted a message about the same problem. I told him the same thing, cleaning doesn't help. He replaced his and the problem went away. I am guessing that after a while they just deteriorate to the point where cleaning doesn't help. It's a cheap sensor, just get a new one.
Old May 1, 2004 | 04:44 PM
Ron in SC's Avatar
This problem happen once before a few years ago and it turned out to be the connector. It had a fair amount of corrosion on it. After I cleaned it off the light went off.
That's why I was thinking maybe it was the connector. There is no continuity between the two wires on the connector, in other words when I check it with the ohm meter there is not a complete circuit. Should there be?
