Replacing Fan Clutch
I know Performance Products has the tool (if you don't want to fabricate it). Not sure if anyone else carries it.
The groove on the bracket is about the 2 oclock position behind the hub. Get the tool in the groove then slowly turn the fan until you "feel" the hole. Then loosen the bolt (8mm).
edit: This applies to a M103. If you meant your Ferarri, then I can't help. ;-) Note: Be clearer about the car for help!
BTW, the problem was a loud clicking sound when engine was hot and idling, coming from the fan clutch area. The sound was getting 5x louder when I stopped and held the fan blade,with engine still running. So, I figured it had to be either the fan clutch or the bearing. I went for the clutch, which was sort of loose anyways, because that sound was not typical for a bad bearing. I guess now my car will get a new bearing, which BTW only comes with a bracket.
I bought the parts from buymbparts.com. Placed an order early Monday morning, got the stuff at 10:30 A on Tuesday. The BEHR fan clutch was, I think, around $125 with free shipping.
