anothe check engine light question
Old May 25, 2004 | 04:42 PM
joeray's Avatar
2000 CLK 430 Conv.
HI
I have a 1988 300E and it has it's check engine light is always on for quite some time now.
I did a search for what might be the cause of this, but only found diagnosis instructions for a 94 model.
Is there any way to find out what might be the cause of this for a 1988 model?
thanks in advance.
Old May 25, 2004 | 09:44 PM
Jer's Avatar
Jer
1994 E320
The codes must be interrogated via the X11 diagnostic connector on the driver's side wheelwell. You need a pulse counter or an LED to read the codes.
Old May 26, 2004 | 12:04 AM
zeronero's Avatar
Mercedes-Benz 400E
As far as I know joeray, only models with the M119 and M104 engines from California have the LED that tells the codes. Basically '92 or newer cars.
You'll have to use the method Jer describes
