18mm vs 23mm front coil spring pads
Old Jul 28, 2018 | 10:57 AM
86300E's Avatar
300E
First post here so please be patient.
I've done some research on this spring pad issue and it looks like the 23mm pads are correct for the MB OEM front springs for an 86 300E.
All other options are 8,13,18mm.
My question is if I install 18mm pads instead of 23mm pads is that really a big deal?
5mm = about 1/5 of an inch.
Any other issue here other than the car now sits 1/5 of an inch lower?
FYI, a parts dept. employee at a MB dealership was nice enough to print out the sheet describing the system used to match up spring pads to spring color codes. For model 124.030, the "points" start with 45.
Then in my case 4 points are added for automatic transmission and 3 are added for a sliding sunroof. 45 + 4 + 3 =52, and 52 points calls for 23mm pads.
The sheet shows these shows spring color options and points as follows:
49 points: Red spring, 18mm
Blue spring, 13mm
50-54 points: Red, 23mm
Blue, 18mm
55-60 points: Red, 13mm
Blue: 8mm
61- Red: 18mm
Blue: 13mm
So if I don't have a sliding sunroof I'm down to 49 points and according to this sheet I can now use 18mm pads?
That's why I'm thinking it's really not a big deal if I use 18mm.
Just in case this now may sound less confusing, even though this sheet form a dealer shows the only spring color options as blue and red, the OEM MB springs I got had 3 yellow and 2 red dots on each so I assumed red.
And I wasn't able to reach in and feel the dots on the existing pads. From whai I've read, 1 dot / burl is supposed to be 8mm, 2 is 13mm, 3 is 18 and 4 is 23mm.
Thank you all advance for any responses.
Old Jul 29, 2018 | 04:25 PM
Floobydust's Avatar
2018 GLE350, 2014 G550, 2000 SL500, 1980 TR8, 1995 E320 Cabriolet
Keep in mind that since the springs sit about halfway in on the control arm, any change is spring pad thickness or spring height will end up being about double that at the wheel (e.g., a 5 mm delta on the pad will be about at 10 mm delta measured at the wheel). From a functionality point of view, I think either would work, although I think if the front it is better to err on the side of thinner so that if the car doesn't sit perfectly level you at least have forward rake. Just curious, what's wrong with the pads you have now?
Old Jul 29, 2018 | 05:23 PM
86300E's Avatar
300E
Last oil change my indie said spring wasn't sitting right. Car only has 60k miles but is still 32 years old so going for a complete front end rebuild since all parts down there are original. He has no problem with me getting parts so all was fine until the four different coil pads option surfaced. I figure while getting new springs why not put in new spring pads too. Ended up just getting 13mm and 18mm before seeing that maybe should be 23mm. Unless he has a problem with the 18mm I'll get the 23mm. Who knows, when he pulls the old ones he may see 3 bumps / burls on them which means the 18mm is original size
Should the original pads stay anyway?
Thank you for the response.
