Misfire
Old Sep 29, 2018 | 03:33 PM
Fenrir425's Avatar
1993 300e 2.8 m104
Misfire
Trying to narrow down what i need to do for a 1993 300e 2.8 m104 starts up but only fires sparks from middle ignition essentily running on 2 cylanders it is not ignition coils as ive swapped them and only when a coil is places in the middle will it fire these are all my codes Socket 6- 3,4,6,8,9 Socket 8- 4,8,11,13,21,22,28 Socket 14- 3,9,14, My throttle and harness have already been changed out and ive heard in another thread that a bad crankshaft position sensor would cause the two outer inginition plugs not to fire
Old Oct 1, 2018 | 12:17 PM
teahead's Avatar
1994 e320 coupe
check resistence of spark plug wires?
My m104.980 in my 1990 300CE had zero in some of my wires.
Old Oct 1, 2018 | 01:02 PM
Fenrir425's Avatar
1993 300e 2.8 m104
Im getting 1500 out of all wires is that low or good?
Old Oct 1, 2018 | 01:46 PM
teahead's Avatar
1994 e320 coupe
Should be good.
Sorry, no experience with that engine type. I barely know anything about M104.980 and M104.99x.
Old Oct 1, 2018 | 05:10 PM
Fenrir425's Avatar
1993 300e 2.8 m104
Im going to change the ecu hopefully that vlears things up
