W124 Low Idle on Cold Start
I’ve noticed there’s a problem with the idle control. On a cold start the idle won’t raise to around 1000rpm, it’ll go lower than normal around 500rpm. When you turn the air on on the revs will go down but not back up again, also if you turn the steering wheel right to the end the idle will go really low and the car will cut out of the time. What could be the issue?
