Swaybars
Old Jun 14, 2004 | 01:28 PM
lino's Avatar
1989 300CE
Swaybars
Someone mentioned that a great upgrade would be to get SPORTLINE sway bars or Limo front and E500 rear swaybars.
I was wondering what car the limo front sway bar is from and what year E500 rear is from?
Thank You
Old Jun 14, 2004 | 02:32 PM
cap'n jasper's Avatar
W124
The Limo front bar is from the, err, Limo!:p
Seriously though, it's also used on the Sportline Convertible.
Have a read of this thread..
https://mbworld.org/forums/showthrea...highlight=limo
and this..
http://www.meimann.com/images/merced...4_swaybars.xls
Try the search button at the top right of your screen before posting questions, chances are someone's already asked it before.
Old Jun 15, 2004 | 02:09 AM
lino's Avatar
1989 300CE
Thanks! There is a lot of info there. I'll have to finish reading tomorrow.
I didn't know that there was a W124 Limo. I have seen limos in the W100, W123, W116, W126, W140 and W220. My apologies. Anyway, I found a W124 today:
Old Jun 15, 2004 | 04:23 PM
lino's Avatar
1989 300CE
I just acquired a few things:
Eibach Sway Bar Box (Not the sway bars unfortunately)
and
W124 1988 300E OEM Front and OEM Rear Sway Bars + Bushings
From what I read so far, I understand that my 1989 300ce has a 13mm rear bar and the sedan has a 15mm rear bar. I was wondering if I should consider using the 15mm rear bar to replace the 13mm that I have on my coupe currently. Buying the Sportline Plus sway bars will be a future upgrade. If not, can someone tell me which bushings I have?
Thank You
Old Jun 15, 2004 | 06:25 PM
W124
Those bushings are standard ones. All the info regarding them is on the above spreadsheet.
The rear bar is a swine to change and the difference in price between a 15mm bar and a 16.5mm bar is small so go for the 16.5mm one.
An empty box will not improve your handling (maybe if you cut it up and use it as a rear spoiler.. )
Old Jun 15, 2004 | 09:48 PM
lino's Avatar
1989 300CE
I have the 15mm here now, that's why I was asking. When I do buy new ones, I will probably buy the e500.
Old Jun 15, 2004 | 09:49 PM
lino's Avatar
1989 300CE
