E 220 1994 white smoke
Old Jan 3, 2019 | 08:12 PM
Kamel Jolani's Avatar
E220 1994
Hey guys,
I have E220 that is in good condition.
I was visiting a friend and everything was ok. Then when I'm leaving I tried to switch it on a pop sound and it turned off. Tried again and it worked. When I drove home it was a very short distance and I noticed a white cloud coming up from the exhaust. I tried to smell it but I noticed nothing. I turned it off for half an hour and came back to check for Engine oil and it was OK. On the proper level
​Coolant and it was OK on the proper level and I opened the engine oil cap to check for any mixing but I noticed nothing
​​​I need a solution for this crazy problem and I need to know what could be the problem ..
Old Jan 27, 2019 | 03:51 PM
speedn_j's Avatar
06 s500, 95 e320, 01 e430
If you have white smoke that isn’t a steam type. Check the transmission module. The vacuum diaphragm can leak trans oil into the intake then burn out the exhaust. I think it’s the curved vac port on the top on the intake(not 100 percent sure) if it’s oily.
