M104 low idle
Old Jul 25, 2019 | 11:34 AM
jayster333's Avatar
1995 E320 wagon
M104 low idle
Hello all,
I am new to the forum and have resorted to making this post in hopes some of you may have some useful tips and advice. Prepare for a long post! I purchased my 1995 E320 wagon with some issues that I’ve been steadily working through. I have found an issue though that I cannot quite put my finger on. My car idles at the normal 1000rpm upon cold start, down to 900rpm after a bit, then down to 500-550 afterward. This low of an idle causes my car to vibrate, especially in drive and reverse. I have a check engine light and a mixture of codes but have gotten it down to code 2 (heated oxygen sensor inoperative), 3 (lambda control inoperative), 5 (exhaust gas recirculation inoperative), and 6 (idle speed control inoperative). These are all using the factory led diagnostic codes. The car runs perfectly otherwise. The ASR light has come on once or twice causing the throttle to be unresponsive but doesn’t seem to be an issue anymore. The only other weird thing I can attest to that may be normal is a suction or whistle sound at 1900rpm in drive that I cannot duplicate in park. Okay so now to what I’ve done to try and correct these! I changed the fan clutch (irrelevant), spark plugs (also irrelevant), mass air flow (was getting a code for it), replaced the battery (mostly because it died). I’ve done an at home smoke test to check for vacuum leaks and haven’t had any luck... I suspected my problem was coming from the throttle actuator as I know of the biodegradable wire insulation but after removing it appears to be a new part with nice wires, so since I was already in that deep I replaced the intake bellow, lubricated the throttle linkages, and cleaned the resonance valve which also looked good and in tact. As far as I can tell the harness has maybe been replaced or repaired as it is wrapped with a sort of fabric tape on all the under hood harness. I’m pretty frustrated with this and unsure what steps to take next, and having already done so much digging would prefer to fix myself instead of have a shop do it, as there are many experienced Mercedes shops near me. Any advice would be appreciated
Old Mar 31, 2025 | 11:02 PM
antiva's Avatar
W124 E320 W211 E63
M104 low and rough idle
Hello. 1995 E320. Low and rough idling. Fine on start but after a few seconds (minute) idles low (550-600RPM) and rough, especially on D & R. Is a bit better on P & N. Engine harness has been replaced. Sometimes I get a nr3 code (lambda inoperative) that throws an engine light on. Could it be just the O2 sensor? Thanks everyone.
Old Mar 25, 2026 | 11:15 PM
E320Emily's Avatar
1995 E320 Sedan
Question OVP Relay Possibly
- Hey so, I am experiencing the same issue and I have replaced my O2 sensor. If anything I thought it was the MAF but I replaced that recently as well so I am lost as well. I have not been able to identify any vaccum leak in the system and I have seen some forums mentioning the OVP relay so thats what I'm checking next lol. If that doesn't fix the issue than im not sure what to do.
