W124 Wagon Ride Height ISSUES
1995 E320 wagon
Hey guys
I have replaced the spheres and put in a used self level valve. However, the ride height is still not adjustable. Nor does the car raise back up to normal with added weight. Any troubleshooting ideas here?
I have a slightly different problem, the suspension would rise but then it wouldn't go back down. I got a dealer to have a look they replaced the accumulators ( sprees? ) and that fixed the issue.
If you have refilled the system properly l cant see why it shouldn't work. Unless the used valve is not working.
If you've got a turbo diesel and the power steering is working then it isn't a problem with the pump.
Maybe you need to check incase any of the pipes are blocked.
