Door pillar rattle
95 E320
Door pillar rattle
I have a '95 E320 and there is an annoying rattle coming from the driver's side door pillar. I don't know it it is the seat belt height adjuster or the door lock or what. Any ideas?
I just removed mine from the 500E (to be re-covered)...there's not much in there...a metal clip at the top and the adjuster/slider(which is all plastic I believe). Sometimes the metal clip at the top breaks or comes out of the body.
I say take it off...2 screws hold cover on at bottom, 11/16 bolt holds belt to body...then slide up pillar and its off...easy (2 minutes)...maybe you got a coin stuck in there or something.
