Looking for info on cam oil sprayer mod
After finding some worn cam lobes on 88 300TE, have installed good used chilled cam/rockers etc etc etc. I Looked at the included, matching oiling rail/sprayer which uses a third bolt (instead of two) to prevent lifting at high rpm. I noticed it has a slight dent near #1 cyl, not bad maybe a bit less than a mm of deformation. I know it will work, but probably not ideal especially in that location. Rather than look for another oiler, was thinking of modifying the original with the "u-shaped" hold-down, but can't even find a photo of it. Do they sell these things or does one have to make it? Thanks
