I made long video of how to remove W124 dash and replace its vacuum actuator pods
Just trying to spread the word. Note that there are only 2 PN's left of the 6 PN's that are available from Mercedes or aftermarket. On the dual diaphgram pods you can buy one of the two pods that are available, remove their arms (white plastic just snaps it on), and you can take off the old arm from the old pod and transfer it to the new pod. NOTE: This trick only works on the dual diaphgram pods. Last resort you can get just the rubber diaphgram inside the pod that you can replace at a place called Performance Analysis in Tennessee, although you can't order on their website. You have to call them. Their part numbers for the two different diaphgrams are 2010 and 2020. On the W124 and W126, you can use one of their diaphgrams on the "center" pod, which is a single diaphragm. They are inexpensive, not sure how long they will be in business from the conversation I had with them. . Get a bunch and store them the rest of your life!
