Odometer failure
Have a 1990 300 D with 280,000 miles, two days ago the odometer (both trip and main) stopped working, the Tach and Spedo are working fine.
Any ideas?
Thanks in advance
AJM
- Get a used speedometer and set the odometer to your current mileage.
- Have an MB mechanic or dealership send the speedometer to VDO for rebuild.
- Order new gears from www.odometergears.com.
These gears available through odometergears.com are custom-made because VDO does not sell the original gears as spare parts.
Did you happen to try resetting it while the vehicle was moving? Though I am not certain about your particular yr/mod most in that era had issues with the friction hold being lost between a gear and the shaft. I had to remove my dash, pull the cluster and go through the procedure of forcing the shaft out while using a stiff wire to hold the dial numbers in place. Once the shaft is out you score or rough the outer surface. Re-install the shaft and press it into the gear. Took some work but it works just great.
Best of luck
Steve
