Mercedes w124 300d help
Old Apr 25, 2020 | 04:28 PM
Ivan__m's Avatar
Mercedes w124 300d 1989
Cant find anywhere my problem
so i have a w124 300d 1989 and there is absolute no climate control working nothing on the center console(non A/C version)i tested the fan and it works great i changed the relay/resistor what ever it is under the windshield and nothing when i put the multimeter says 0 volts on all 4 fan speeds?what can i do im going crazy iv been trying to fix it the last 2 weeks...(i checked all fuse good)and sorry if i made mistakes in writing im trying my best
Old Apr 26, 2020 | 06:19 AM
optimusprime m1's Avatar
W124 260E
Ivan can you post a picture of your console for the heater control .I dont understand weather you have air con or not . Or do you have the normal heater as standard in most models .
Old Apr 26, 2020 | 06:26 AM
W124 260E
Ivan if you have not checked this item out do so now . Its is split or
burned out .
Old Apr 26, 2020 | 11:51 AM
Ivan__m's Avatar
Normal heating no air coondison
burned out .
Normal heating/cooling and there is no blade fuse in engine compartment
Old Apr 26, 2020 | 11:54 AM
W124 260E
You look again on the other side .All W124 have them . Just like mine just bog standard hot or cold heater blower .And no aircon.
Old Apr 26, 2020 | 12:50 PM
Ivan__m's Avatar
Cant find it
Old Apr 26, 2020 | 01:50 PM
W124 260E
I will find out for sure pn Monday, and come back to you . I took my camera outside to picture mine ,.,.But like you there is not one on show .
Old Apr 27, 2020 | 04:51 AM
W124 260E
Looks like only fuse is in the fuse box ,,and you know about that one . I will see if the heater runs through a relay .
You could switch it on and chech if the heater blower moter is receiving the 12 volts . If it is then the brushes in the cage motor is toast also - No relay involved .
Old Apr 27, 2020 | 05:34 AM
W124 260E
...The power to the havc is taken right from the ignition switch .So switch the heater on and waggle the key see if it starts the heater motor . Do check the fuse in the fuse box again and as a secondry change heater fuse over for another .If these are white metal type they all need thrownig away and changing for copper and ceramic like they sell in the boat chandelers .Check the power at the number 7 fuse in the fuse box for heater motor .
Old Apr 27, 2020 | 09:47 AM
Ivan__m's Avatar
Gonna try
gonna try it today i just bought brand new panel for controls inside but i thing my old one isnt even broken and there are 0volts to the blower motor i just got my 3rd regulator the cage one in garage if this 2 one doesnt work
Old Apr 27, 2020 | 01:30 PM
W124 260E
Let us know how you get on .
Old Apr 28, 2020 | 07:09 AM
Ivan__m's Avatar
Still nothing but i did see that someone replaced ignition switch since the key pattern is similar to the orginial key but the orginal key wont turn the switch
Old Apr 28, 2020 | 08:55 AM
W124 260E
The ignition switch as a lot of contacts inside . And it is used for the heater system hot wire . You will have to trace back to find the problem.. Ask the chap who you had the car off if he did anything .Ave you a wiring diagram ? If not i can take a picture of diagram from my manual and post it up on hear for you.
Old Apr 29, 2020 | 04:31 AM
Ivan__m's Avatar
The car has been saved from being parted out and send to the junkyard so only thing iv benn told is that it was changed so a wiring diagram woud be nice since i guess gonna be a lot of wires
Old Apr 30, 2020 | 04:13 AM
W124 260E
Ivan i will do that for you a little later to day . Trevor
Old Apr 30, 2020 | 04:41 AM
W124 260E
Ivan is this any use .
Old Apr 30, 2020 | 04:46 AM
W124 260E
Ivan can tou see that plug thing above the duovalve open it up see whats inside it .I dont think this will help you ,,,i am searching
Old Apr 30, 2020 | 05:14 AM
W124 260E
Ivan save a lot of time and get in and check out that ignition awitch. To rule out that you just might have a wire off or a birds nest of wires under there , A few guys on the forum have had ignition switches go down after finding heater is no longer working . Your sure that you put voltage to the squirrel cage and it did work .. auto electric fitters use the ignition switch to fit the alarm to the car and might have knocked a wire off .
Old Apr 30, 2020 | 07:59 AM
Ivan__m's Avatar
Still searching how to take it out since i never took a agnition switch out do i have to remove the whole bottom part of plastic?and 1 more question where in hell do i connect the speedo cable?i cant see it with my eyes do i go under the car or do i take the wood trim from above around the gear selector?
Old Apr 30, 2020 | 01:40 PM
W124 260E
Why do you need to fit the speedo cable ,,,whats wrong ewith the one you have,,, or is it that it is missing ? Well this is fitted to the rear of the speedo clock console you pull the whole lot out from the dash with the help of a pair of hooks the other end of the cable screws to the spigot on the gearbox . And yes the bottom of the dash needs removing to get in to the switch from the below Lot of info on how to do both these jobs will be on youtube in video form to help you see how it is done.
Old May 3, 2020 | 11:25 AM
Ivan__m's Avatar
There was no cable inside only the tube around when i pulled it out only half of the tube was left thats why im changing speedo cable but sadly bad weather here so i didnt do anything yet waiting for tommorow shoud be sunny
Old May 5, 2020 | 07:03 AM
Ivan__m's Avatar
What a mess
Wires hanging and lead to nowhere
There is a cable going as well nowhere on left that with a head cable
So bouch of electrial tape thats the connector to the igniton switch whats next do i have to drop the stering to be able to disconect it?
And here is someones rust repair but more importat again wires splited and 2 wires going to the back of the car dont know where hoprfully not important.And there is a dashlight bulb with a blue wire going nowhere just hanging cable cut off cant find where its suppose to go
Old May 5, 2020 | 07:10 AM
Ivan__m's Avatar
im gonna leave it here you guys analize and say what shoud i do next i never liked working on electric stuff since i always short it somewhere 😆
Old May 6, 2020 | 12:36 PM
W124 260E
Ivan you need the help of god to sort that out . Whats the rest of the car like ? I wouild say some one was playing in there and damaged most of the wires .Where they go is any ones guess .It will need a good elecronics guy to sort it out if you dont sort it will be a fire hazard . Or spend and get a good schematic diagram on the wire layout . Wish i could help you in some way .
Old May 13, 2020 | 03:35 PM
Ivan__m's Avatar
left the car as it is just put it all thogeder for now there is no one who woud work on it so it leave me alone to work when i get some time for it
