1990 300E Runs Great -STOPS Runs Great - STOPS
Old Dec 10, 2020 | 11:35 AM
geneb300's Avatar
1990 300E
Angry 1990 300E Runs Great -STOPS Runs Great - STOPS
300E was in storage for about 14 months due to nasty heart surgery. Started occasionally. Drained fuel, replaced fuel pumps, filter, accumulator, fuel inlet line. Runs great for about 3 miles and dies. restarts immediately an runs for 2 miles,and dies, progressively shorter distances. ChangedOVP valve same problem.
Old Dec 24, 2020 | 06:33 AM
Trevor Hadley's Avatar
mercedes w123 260e
So what engine are we talking about .You see there are a few engines fitted to you W124 M103 M104 to mention 2 of them ..?
Old Dec 27, 2020 | 01:30 PM
geneb300's Avatar
1990 300E
Engine is M103.9
Old Dec 27, 2020 | 02:30 PM
mercedes w123 260e
I would try another fuel pump relay . They do cut out when hot . And also the crank position sensor can show up with the same problems .Check the cps with multi meter for ohm cold .And start.it up , then when it stops you check ohm again .
