1992 300ce shifting problems
Old Dec 14, 2020 | 10:48 AM
Rafe's Avatar
1992 300CE
The transmission seems to slip a bit when shifting from 2nd to 3rd under moderate to heavy throttle. Smooth under gentle throttle. If you lift the throttle between shifts it works better. No problem downshifting. Fluid and filter changed less than 3000 miles ago. Where should I begin diagnosing the problem? Thanks
