300e 1986 temperature device on cluster Panel
![Exclamation](https://mbworld.org/forums/images/icons/icon4.gif)
Does any body know how to fix or where I can get the temperature disply device that is in the cluster panel that displays the temperature its right u
nder the speedometer
My works is just that you cant really see the numbers completely the little screen seems to be ruined
HELP HELP
HELP HELP
I guess the modul is just dísplaced in the cluster. If not and the LCD is gone you may try EBAY.
1994 E320
As bamberger said, look on eBay. A new display goes for around $250-300, since it is such an obscure item. You can get a used display for less than $100.
![Thumbs up](https://mbworld.org/forums/images/icons/icon14.gif)
GUys the new part from two different dealers by me in NJ is 470.00 it is such a crazy cost that I took your advice and went to ebay
I found the whole cluster panel for 100.00 used and according to the seller the LCD is not cracked or broken so I thought it was not a bad deal and I have some extre parts for the future at this point
AGAIN thank you
You guys are the best
AGAIN thank you
