1995 w124 m104 engine harness help!
I just found out the connector not connected is the crankshaft position sensor! That may be it!
EPC will typically show footnotes for a component so it correctly matches to the correct 'as of' or 'up to' vin# noted on the footnotes.
I seen several recent mistakes DIYers have done with harnesses as well as with speed sensors.
if it EVER stops raining, I'll connect it and will update. It's really in a tight spot near the bell housing.
Thanks!
