Newbie issues with 260E...
Old Sep 1, 2004 | 09:46 AM
Benz0's Avatar
I have had a 89 260E since I grad'ed from high school (bought it new in 1989)...it's got about 203K miles and is just now strting to show age...
Issues:
1. Hesitant take off - on take it drops to a very low RPM then jumps up and goes - I searched on hesitant take and RPM's on this forum to no avail
2. Tranny is starting to slip a bit when cold (take from 1st - 2nd and then whines pretty high RPM's into 3-4th) may be a fluid issue but no leaks are detected on the driveway - may be during driving? Does not have the problem when its driven for a bit
3. rattling when hitting bumps and the steering moves with the rattles - bushings - sway bar - control arm ball joints?
4. Radio is a POS now and I need a replacement - its o.e. and only one speaker works
5. Windshield washer fluid resiviour leaks all fluid out - around the pump motors - maybe just bad pvc tubing they are pretty stiff from age
6. Antenna broken - need a boot and replacement power antenna
7. The AC vent - sticks on Defrost on the center vents - the side bloq cold air but the center is stuck on defrost? Odd?
Also, know of any distributors or forum sponsors I can throw some business thier way on replacement parts?
Any help with these issues or solutions would be great! I am love to wrench on my own junk and am also an avid rock crawler (Jeeps mainly) and working on a CJ5/7 rock buggy...
Thanks!
Benzz0
Old Sep 1, 2004 | 05:44 PM
Jer's Avatar
Jer
1994 E320
1. Does this happen only when you start the car for the first time for the day? I experience the same problem.
3. At 203K miles the rear suspension link bushings could be worn out. For the steering jack up the front one side at a time and shake the wheel at the 3 and 9 o'clock positions. Play = worn idler arm bushings. Shake at 12 and 6, play = ball joint.
7. If the vent never turns off, the vacuum actuator might be leaking, or the switchover valve is defective.
I purchase parts from The Parts Bin, because they are in NJ, and I get next-day delivery. Lots of people use MercedesShop. They're all good.
Good luck!
