Need hub centric rings?
Old May 21, 2021 | 10:32 AM
UAhmad's Avatar
e124
What's up folks,
I recently bought some used AMG Monoblock wheels for my W124 and am a little confused on sizing/mounting. After attempting to mount w/ a 10 mil spacer, there was a severe shake at 35+ mph. The previous owner did include some hub centric rings that he used with his C36 AMG but turns out they did not fit on the hub of my car (too small). I guess my question is does anyone know what wheels these are in particular and what the center bore size is so I know what size rings to order? From what I've researched so far, the W124 has a 66.6 center bore and if I was to guess, the wheels are closer to 74.1 so I'd be looking at these? -
Amazon Amazon
Any help is greatly appreciated. I tagged some photos of the wheels if that helps.
Old Jun 24, 2021 | 11:58 PM
bmwpowere36m3's Avatar
'11 E350, '11 E550, '98 M3, '95 E320
With a 10 mm spacer, there likely is not much of the hub centering ring engaging the wheel. So, while yes you need a proper hub bore ring adapter for your wheel. You may also need a hub extension due to the spacer width.
Similar to this:
https://www.turnermotorsport.com/p-2...xtenders-pair/
used on my M3 with 10mm spacers. Not sure if their made for MBs, or the hub dimensions specifically, as I’ve never looked.
