ABS not working
Is it the ABS relay on the ABS pump itself? The one under the plastic cover? Isnt the ABS light on the dash supposed to come on when the ABS isnt working?
Thanks.
I don't know if there are self-diagnostics for the ABS. You might be better off taking it to a dealer for diagnosis. Also, if you worked on the front brakes recently, check that the speed sensors are present and plugged in.
