Right Dashboard Turning Indicators Not Lighted
Hi
I owned a W124 E220 Masterpiece Malaysia
When i flip the signal indicator to the left, the dashboard green arrow indicator blink and the outside signal light blink as expected
However when I the signal indicator the Right, the dashboard didn't light up but the external signal link blinked as expected
Q1. What is the probable cause?
Q2. How do I repair this
Q3. If there is a need to change any parts, please advise part no
Appreciate all input.
Thank you
Doc
Thank you
Doc
2021 S450 4Matic
If you turn on the Hazard Light, do both (left and right) dashboard indicator lights blink as usual?
Anyway, it could be just a blown light bulb.
If so, you need socket lamp (#44) as in here:-
https://www.nur-benz.com/product/537...w124-pro001186
Examples of how to remove the instrument cluster:-
(At 3:55, you will see the left and right indicator lights on each side of the central speedometer.)
Sylvania Turn Signal in my 07’ W211 E63
Sylvania 3457A Turn Signal
Newly rebuilt Headlight w/new lense and Bi-Xenon Led Low Beams.
My E63 during my 2nd phase Build (Rear Main Seal, Tranny Valve Clean, New Drive Shaft Discs, Subframe Bushings, rear Arm Bushings, Rebuilt Air Springs and new Shocks, 3.06 Gear Ratio Swap W/LSD)
Newly painted front end
Rear View
Please let me know of your Led Turn Signals would fit the Connector which hold the OEM Sylvania 3457A Bulbs?
Last edited by E63007; 05-12-2024 at 02:48 PM. Reason: Oops, I posted this on Wrong Thread! Can’t Delete it?
