Becker - problem with memory after switching it off
Old Apr 7, 2022 | 03:12 PM
SolidBoy's Avatar
w124
What is the cause of this situation:
After switching off the ignition the radio memory reset and i need to enter the pin code....
My ideas:
- memory circuit board fail
- some extra battery on the radio board
- voltage peak after ignition switch off
Wiriing is good:
1 - 0 Voltage (ground)
2 - Ignition
3 - illumination (+12V)
4 - constatn +12V
Old Apr 22, 2022 | 09:22 PM
bicylindrico's Avatar
I would suspect maybe you are losing the circuit 30 (constant 12v). I would make sure the constant hot is always there but if so maybe there is a battery or capacitor on the board like you stated. Still should be an easy diag and fix
Old Feb 19, 2023 | 12:02 PM
Isawelvis's Avatar
Veteran: Air Force
, 2023 BMW X4, 1991 190E
Try the guys in NJ who specialize in Beckers radio. I just sent my old one to be repaired for my 1991 190 E. I found them on Ebay by searching for Becker Radios Good luck.
