Transmission Help w124
Old Oct 19, 2004 | 05:10 AM
shams13's Avatar
E240 2004
I have 230E 89 model
going at 3rd at low speed such as at 50Km/h or below, as soon as i take off my foot from the gas pedal, it shifts 4th. Why is this?would adjusting vacuum modulator help in this case.
car should be driven at high RPM or Low. Which is better.
Would changing ordinary ATF with good fluid(synthetic) and filter help in smooth shift.
Old Oct 19, 2004 | 10:21 PM
Jer's Avatar
Jer
1994 E320
If the fluid is old, a change will help.
Adjusting the Bowden cable might help with the shift points. If you are gaining speed when you release the accelerator, you are telling the transmission you are done accelerating and are ready to cruise at a steady speed. Adjusting the modulator will only affect the smoothness of the shifts, and is not recommended, because too soft a setting will cause flare.
Old Oct 20, 2004 | 01:53 AM
shams13's Avatar
E240 2004
what is a flare in transmission??
Old Oct 20, 2004 | 01:58 AM
shams13's Avatar
E240 2004
i don't gain speed and naturally i can't gain speed when i release the gas pedal. there will be no gas to the engine and RPM will tend to decrease but it shifts to next.
suppose i am driving 50Km/h and at 3rd with 2500RPM, there is a hump ahead, so anyway i have to decrease the speed and may be apply brake. As soon as i take off my foot from gas, RPM will go down, but it shifts to 4th(that is actually not needed). I don't know why mercedes has made the tranny like that.
Old Oct 20, 2004 | 09:56 AM
Jer's Avatar
Jer
1994 E320
The transmission is not supposed to upshift as soon as you release the accelerator. What I meant earlier was, if you are picking up speed (as if stopped at a red light then you resume driving when the light turns green) the transmission starts off in 2nd, then goes up to 3rd, and eventually 4th. If you hold down the accelerator for a long period, the transmission will stay in 3rd (or 2nd) gear longer to give you more torque. Then when you let back on the accelerator the transmission knows you don't need all that power, and upshifts to 4th. The Bowden cable adjusts these points.
Flare is when the transmission changes gears, and there is a long delay between them. I think this can wear out the brake bands.
Old Oct 21, 2004 | 07:08 AM
shams13's Avatar
E240 2004
where is the bowden cable and how to adjust it.
Old Oct 22, 2004 | 01:27 AM
349 BHP's Avatar
Mercedes E320 , Lexus IS350
i want to adjust mine
but my 94 dont have BOWDEN CABLE!
