W124 wheel offset
Old Apr 21, 2023 | 10:30 PM
RF20's Avatar
E320
W124 wheel offset
My 1995 has 15 " rims with a wheel offset of ET 44 , will 15 " rims with ET 37 fit without a problem ?
Old Apr 24, 2023 | 01:46 AM
cemarmutcu's Avatar
w124 e220
fits no problem
Old Apr 24, 2023 | 04:29 PM
Serhan's Avatar
2021 Glb35 AMG (2013 GLK 350)
It should normally. I have 2 aftermarket wheels, TWS Clypse and TWS Mandrus Estate, with ET42 in comparison to OEM ET51. One fits and the other didn't clear the AMG brake calipers. So it depends on the wheel design too. You can check:
https://www.wheel-size.com/calc/
You can search the wheel and your model if you can find any fitment photos.
Old Apr 26, 2023 | 04:12 PM
bicylindrico's Avatar
The calipers can make a big difference between model years on the same chassis
Old Jun 21, 2023 | 04:42 AM
M. Schneider's Avatar
1994 E-Class 320 Coupe, 1998 911 Carrera S (993)
Wheel Offset (ET) and wheel width (?) are related . . .
Guy's, Wheel Offset (ET), and wheel width (?) are related . . .
Typical W124 E-320 wheels are 15" x 6.5" with an ET44 .. Sportline optioned E-320 have wheels 15" x 7" with and ET41 .. My '94 C124 coupe has aftermarket OE style 16"x 7.5" ET37 alloys. The fitment is fine, although the wheel is pushed out by about 3 to 4mm. Tire size choice is also critical: OEM size vs plus 1.. I'm running *Michelin's in the Plus-One tire size 205/55VR16"
* Pilot Sport A/S 3+,, 205/55/VR16" as Plus-One size to that of OEM 205/70/15" tire... Michelin Tire Pilot Sport A/S4 supersedes the A/S 3+ in Fall of 2022yr.
'94 C124 3.2 Coupe w/Sportline option; OEM 8 hole 15-inch Alloy rims 7"x15et 41 ... Aftermarket 8 hole Alloy 16-inch rims 7.5 x16et 37 ...
