W124 cooling problem
I have w124 200e (with ACC) and have electrical problem with the two fans.
Aux fan and radiator fan works all the time.
I change the thermoswitch 0065459024 and the radiator fan now DO NOT engage even after 95 degrees.
I'm not able to diagnose it anymore... could you please help
Like Hubert mentioned the fans come on both when the wires (sensor) are shorted or open. It expects a middle range (~3Kohm down to ~100 ohms).
This is a safety feature so that if there is a disconnect the owner knows there is an issue as the fans will run all the time and it is safer for the fans to run then not to turn on at all.
So look for opens. Of course it could also be a stuck relay issue too.
- Cheers!
