head gasket fixed, now wont start
THe fuel rail I marked which was return and supply, but the marks wore off due to the presence of gasoline. I am not sure at this point whihc is which. I know that on the fuel rail the line that goes to the pressure regulator is the return, and the other is te supply. What I don't know is which of the actual rubber lines is which. THere is one line that looks like it goes through a filter, but that the A/C line runs through, and the other just goes straight back under the car. Any ideas on which is which?
By the way, that A/C line running through the fuel line is WEIRD! Anybody else ever notice this?
Thanks,
Rob
Oh yeah, I also found that the mechanical timing was off by one tooth on the intake cam. I took it back apart yesterday and fixed this also.
So, compression is good (checked it yesterday), spark is good, and the timing is correct. (It has HFM electrical distributorless timing, so that can't be a problem)
Any ideas?
Thanks,
Rob
Are you Sure your spark is good for every cylinder? I had a very simialr problem on a C280 (95) and it was the upper harness going bad. How many miles on this car?
Jonathan
