OM606 Plastic Fuel Lines
Greetings:
I'm replacing the hard plastic lines on a 95 E300 with the OM606. I'm having trouble locating 606 070 05 32, injector pump to fuel filter housing (banjo) fitting. MB parts says NLE, every site I pulled up says NLE or out of stock. Pelican has the other banjo fitting line (601 070 53 32) Does anyone have a source? I just replaced the 3 other lines. Thankfully the two banjo fitting lines to the injector pump are currently not leaking but I'd like to replace them while I have the intake manifold off.
That's a pretty vital part to be unavailable.
Thanks in advance
Thanks in advance
