Factory Blutooth radio options for W124 wagon???
Hello,
I'm finally getting around to upgrading the radio in my 1995 E250D wagon. The aftermarket Kenwood radio it currently has does not have blutooth and I really need to have this feature. Are there any factory radios (W210) that are plug and play with a W124? Even if they don't have blutooth but have an AUX feature, I can buy a blutooth adapter to make it work.
Let me know what you use for Blutooth in your W124?
Thanks,
Ryan
Thanks,
Ryan
If you do not need a CD player, I heard the Continental one sold (I think crutchfield has them) look very similar to factory, but has all the bells and whistles as well as period correct.
You should look that up, it may serve your purpose.
The following 2 users liked this post by dolucasi:
M. Schneider (06-16-2024),
ryguy993 (06-09-2024)
Thanks,
I am going to research the W210 radios to see if they will work, which I think if the car is post facelift (94-95) the W210 radios are a direct plug and play. I also ordered a factory radio harness in case the previous owner cut the factory plugs out to install the kenwood unit that is currently installed. If the W210 radio will not work then the Continental one looks as factory as it can get.
Thanks,
Ryan
Thanks,
Ryan
I had a 2001 W210 wagon. I do not recall it having blue tooth but I could be mistaken as it got t-boned about 16 years ago. So my memory could be failing me and I did not even have a smart phone then.
