headlight lens
Old Nov 28, 2004 | 09:58 AM
kathipre's Avatar
89 300E
headlight lens
Does anyone know how to remove the headlight wiper assembly in order to replace the lens? (Left)? Thanks
Old Nov 29, 2004 | 08:51 AM
Jim's500E's Avatar
Yep, ya' need to remove the turnsignals first (they slide out and are unhooked from inside the engine bay by unscrewing the wheel that hold them on), then the wiper panel (2 screws, one under the turnsignal) ;then undo the rest of the 8mm screws and remove the whole housing..the wiper assembly is attached with one nut on the bottom of the lite. Then you can unclip the lenses..but do that inside a house where it is warm, breaking one of the tabs will leave you f$#@ed when the plastic is cold.
