1992-1995 Differential Pinion Question
- does the pinion use a crush sleeve and if so, what’s the part number?
- what is the initial torque on the pinion nut to set initial preload?
- what should the preload torque be set at when rotating pinion with my preload torque wrench?
- what should the final pinion preload read once carrier is installed?
Ron
