Leaking fuel.
Old Jan 29, 2025 | 01:14 PM
aahmes57's Avatar
1995 e300d, 1989 190e and 1998 S70 Volvo
Leaking fuel.
Would someone please direct me to a thread for a 1995 E300 diesel delivery valve o-ring replacement procedure and the part number.
thank you in advance.
Old Feb 4, 2025 | 11:23 AM
aahmes57's Avatar
Leaking fuel
Thanks for the info. I find they sell 2x15x19 mm orings at Ace Hardware. Also the return lines for the fuel,( not the cloth braided kind) a bit smaller by I think .001 but they work well so far. I have an old note about the clear fuel lines, that it is 5/16, and to leave the piece on the stud when you cut it and use a wire tie to tighten down on it. Do you have a spec on the copper washer?
thanks again.
