Alarm
Old Dec 11, 2004 | 02:53 PM
jst216's Avatar
1990 MB 300CE
Question Alarm
HAVING INTERMEDIATE TROUBLE WITH ALARM,...ALARM SOUNDS AFTER ULOCKING AND OPENING DRIVER'S DOOR...ANYONE KNOW HOW TO TURN THE ALARM SYSTEM OFF...LOVE THE CENTRAL LOCKING, HATE THE ALARM........
Old Dec 11, 2004 | 10:49 PM
Diesel's Avatar
Mercedes 2019 AMG S63, 2015 E250 Bluetec. Previous: '18 E63S, '07 E63, '10 S550, '15 S550, '10 GL350
Alarm
When u turn your key to unlock the door, the sensor in the lock is not recognizing that the key is in the unlock position. When the door opens, the alarm thinks the car is being broken into. This is actually a common problem. What you need to do is turn the key to the unlock really slow, or try unlocking it once, leave the key in, and turn it to the unlock position again, then open the door. If the alarm is still going off, go to the passenger's side door and unlock it.
I had this same problem and took it to the dealer, they used some sensor on the door lock and told me that that was the problem with my alarm. The solution is to replace the lock mecanism ($600 CDN), or the tech said, to unlock it slowly. I unlock the door, then turn it a second time, I have had no real problems with the alarm going off anymore when I open the door.
Hope that helps.
Diesel
Old Dec 23, 2004 | 01:25 AM
jst216's Avatar
1990 MB 300CE
Cool
STILL HAVING TROUBLE WITH ALARM...DOES ANYONE HAVE ANY IDEA ON HOW TO DISENGAGE THE ALARM SYSTEM??????....
Old Dec 24, 2004 | 03:28 PM
88MB260E's Avatar
1988 260E
To disable the alarm, you'll have to remove fuse "C" from under the hood. However, this will disable your central locking system, power antenna, and a few other items. For me, I've just got into the habit of unlocking my car from the passenger side.
Old Dec 24, 2004 | 07:31 PM
Sp!ke's Avatar
Often the alarm override switch is under the front passenger side carpet near wgere your feet rest.
Pull the carpet back and look for a switch.
Old Dec 24, 2004 | 09:10 PM
jst216's Avatar
1990 MB 300CE
Thank You, I Will Try That Tomorrow...merry Christmas
