Rear View Mirror Repair
1995 e320 wagon
![Question](https://mbworld.org/forums/images/icons/icon5.gif)
Can anyone tell me how to fix the rear view mirror bracket. It is loose and wobbles a the base. The problem is where the bracket (arm) mounts at the window frame.
I see threaded screws but do not know where I should tighten it.
Thanx
JC
1995 e320
Thanx
JC
1995 e320
1995 e320 wagon
found the fix
Well I found the fix.
FYI pulling the mirror firmly removes it from the upper plate.
The plate with 3 screws screws into the window sill.
The mirror assembly then must be snapped back into the plate with a fairly strong push or meat hammer it into place.
jc
jc
