transmission swap-out + misc oddities.
there are a couple of electrical gremlins as well- no dash lights at all, and
my idle control seems to be all over the place. it seems to rev quite high (1500 or so) for a while, then it goes up and down a bit... but in general seems quite high. - there is also a strange squeak (sounds like a belt, but I can';t seem to find the source) from under the hood, I think it might be the fan clutch?
also, I'm looking for information on the vacuum lock control module that goes under the back seat. I think I need a new one- actually, I'm sure I do. I've come to notice that 124's come in many shapes and sizes, so I have yet to find the correct parts in a scrapyard. - need window switches and other misc parts as well!
Regarding the dashlights, you need to remove the dash and inspect the rheostat solderings.
Check the idle speed stabilizer regarding your idle speed fluctuations. It´s under the air filter housing. Try knocking it with a small mallet and see if that makes a difference. If so, it´s most likely stuck.
The central door locking vacuum pump under the rear seat is the same for all 124 models, except the T and C models which have different ones, I believe.
Regards,
