Shifting Problems with my E300E
Old Jan 12, 2005 | 11:13 AM
rlatham's Avatar
Oh my....my baby is sick I need a cure! I have a 1991 300E with 185k. I refuse to trade this car as my wife has insisted for the last 5 years because I do love it so. HOWEVER, my car is sick and I need help!
I recently was leaving the house and the car refused to "upshift" from low gear. I could shift easily among gears but it still will not go into the higher gear. The car can only go around 25mpg. Does this sound more like a computer/switch problem or physical prob with the trans? Wanted some advice before I take her to a shop. Thanks in advance for any help in this matter!
Old Jan 12, 2005 | 12:30 PM
Sp!ke's Avatar
When did you last have the transmission oil changed?
If it was a long time ago, start with an oil change and see if this fixes it before spending big money on anything.
Old Jan 12, 2005 | 02:25 PM
rlatham's Avatar
My father-in-law did that for me about 6 months ago....thanks for the help!
Old Jan 13, 2005 | 02:29 AM
ashman's Avatar
2004 C240, 2015 GL350 Bluetec
I lost 4th gear once and 3rd was almost gone. tranny had to be rebuilt.
Not sure if it relates to your problem, but I'd have it checked out
Ashman
Old Jan 13, 2005 | 08:31 AM
Jim's500E's Avatar
Sounds as if it could be the valve/switch on the tranny....have a tech check that also.
Is the fluid too low and was it the correct stuff ? (not to insult your in-laws work)
