Seat Belt Light and delay interior shutoff
![Angry](https://mbworld.org/forums/images/icons/icon8.gif)
My 93 400 E has a problem in that the seat belt light flashes whenever the driver door is closed, regardles of the key being in ignition. Also, when the interior light is set at 'O' it does not go out on delay as it should, it stays on.
Has anyone had this problem and a known fix? Could it be the seat belt relay or could the whole unit be bad?
1 Post
08 Lexus GS350 AWD. 08 Lexus RX350 AWD - wife's. 94 MBZ E320 - still have it.
I had a similar problem. Mine was caused by a tiny invisible crack in the fuse cap. MBZ has crappy fuses. Every now and then the fuse gets burnt trough right where the fuse holder grabs it. In other words, pull every fuse one by one crefully inspect it and if there are any burn marks on the fuse cap, replace it.
Let us know if it helped at all.
