Removing Gas struts from a TE tailgate
1988 230TE
Does anyone know the proceedure for removing the gas struts from a 1988 230TE tailgate? I have obtained change-over struts for US$45 but need to get the old ones out first!! Any tips much appreciated.
93 320CE, 72 280SE 3.5, 55 220A, 05 E280CDI, 88 Mini Mayfair, 90 Peugeot 205GTI, 04 Mini Cooper
Have'nt done it but I'm told it's difficult because they are inside the roof, remove the plastic panel on the inside at the rear and take a look.
1988 230TE
Your not wrong.... beautifully engineered - as always. The gas struts have 3500psi of pressure! No surprize considering the close geometry of the linkage. I have got as far as pulling the pin out of the barrel end of the strut, but wondered if there was better method as it is quite a tricky proceedure.
