300e 300se cold air intake
1990 300SE
Hi, has anyone made a cold air intake system for their M103 3.0 engine? *If so where did you get the parts? * I am trying to find a rubber elbow or boot that will attach to the M103 intake and bend at a 90 to accept a tube of either 2.5 or 3" diameter.
Dan
Dan
1991 300E
There's been a lot of discussion about this issue on these boards. I think the general consensus is that the cold air intake for M103's is not worth the gain. I do remember seeing one on EBAY once that used Porsche parts. It think it was about $200.
1 Post
260E , 1989 (for now)
Your current intake system is probably more efficient than any modification you intend to perform.
For most, a modified intake system normally includes the magical K&N filter.
Look at what a Benz owner has to say about the use of a non-stock air filter:
http://www.mercedesshop.com/shopforu....php3?t=115214
I have adapted a morgan-tech intake for my motor, seen below
![](http://memimage.cardomain.net/member_images/12/web/588000-588999/588193_8.jpg)
but I still need to build a heat shield for it, but for over 40k miles I have had no problems with it, the filter is metal so there is no special spray needed (like on my truck's K&N FIPK)
Morgan-Tech.com is the address
W124's
I'm still not a fan of these intakes being placed on our cars.
Denim, doesn't it seem that your intake itself is a little too far in the engine bay?
1991 300ce, 2006 Yamaha Stratoliner
If the intake is not sucking "cold" air from outside of the engine bay it's pointless...looks cool, but so do antenna *****...neither will increase performance.
just need to find someone who is good with working aluminum, I know I am not gaining much power over the original, but I still gained power, by better breathing, and at high speeds the heat radiating off the motor is no match for the high speed air flowing in through the grill
