Water pump
Old Feb 17, 2005 | 07:57 PM
DrTofu's Avatar
1988 300E
Water pump
Just wondering if anyone has replaced their water pump and how much work is it? I'm fairly decent around cars, swapped a 350 into my cutlass in late 90's. I can see 2 screws holding it on and am assuming theres 3 or 4. Also thinking ill have to take the power steering pump off too. Any other input would be nice.
Old Feb 20, 2005 | 07:37 PM
Jer's Avatar
Jer
1994 E320
I do not think you have to remove the PS pump. If you want instructions, I can send you a PDF of the job from the service literature.
Old Mar 5, 2005 | 02:44 AM
frank16's Avatar
1991 W124 w/100k on the dial
Hey I can sure use the service literature for the water pump.
thanx..
Old Oct 5, 2005 | 11:18 AM
A2T's Avatar
A2T
Can I have these instructions too? Im doing a waterpump on my 87 300D. Thanks!!
Paul
pi2060@yahoo.com
Old Oct 5, 2005 | 03:03 PM
DrTofu's Avatar
1988 300E
Sorry man, i dont have them anymore, hardware failure on my pc last week.
Old Nov 7, 2005 | 04:33 PM
Cali300E's Avatar
I have the PDF's if anyone needs them. The pictures make it look so easy... You have to remove the air cleaner and tensioner and loosen the PS pump to get to it.
Has anyone here actually done a pump yet? Looks like I've gotta pull my pump to replace that shorty hose between it and the head.
Old Nov 11, 2005 | 02:18 AM
AMG_Eric's Avatar
2016 AMG C63s
um b4 u pull your pump keep in mind there are 3 different ones for a m104 motor. also the book time to do a water pump is somewhere in the neighborhood of 5.7 hours. that means a normal mechanic can expect to spend almost 6 hours replacing it. a mb tech will be quicker. if you dont wrench for a living expect 8 hours.
if you have the funds just have a mechanic do it. you must remove almost all the accessories off the front including removeal of the radiator if you dont have tools to work in tight spaces.
