Clunk when first pushing gas pedal?
Old Feb 20, 2005 | 01:46 AM
SEA-Benz's Avatar
I have a 1992 300E and have noticed when I have the fan low and the radio off, I can here a clunk when I get on/off the gas pedal. Sounds like it comes from the engine compartment on the passenger side in front of the glove box. Solenoid going bad, or is this normal?
Old Feb 20, 2005 | 02:47 AM
paul9662's Avatar
1999 E55
motor mounts
I had similar problem, check the motor mounts. One side is liquid filled, the other is not.
Old Feb 20, 2005 | 03:22 AM
Nick_M_51988's Avatar
1992 400E (86 300E, 98 S420) - Retired
my clunk turned out to be the front flex disk. does it happen when slowing down too?
Old Feb 20, 2005 | 07:30 PM
Jer's Avatar
Jer
1994 E320
It can be. The propeller shaft and engine will be running at different speeds, so when you release the accelerator, there will be some play before the transmission output shaft and propeller shaft get "in sync."
Old Feb 24, 2005 | 12:01 AM
SEA-Benz's Avatar
Flex disks are new and so are the motor mounts. Makes the noise even in park. I will double check the mounts. The noise is only when I give it some throttle, does not matter if I am slowing or coasting. Thanks for the input.
