Left rear light problem
Old Feb 20, 2005 | 09:17 PM
t.ford10's Avatar
Question Left rear light problem
I have a 300E 1986
The left rear (Driver's Side) turn signal/hazard/marker lighting has gone dead. I checked the fuses all appear fine. The brake light/normal rear light is working. No loose wires in the tail light assembly. Can anyone think of anything else to check?
Old Feb 20, 2005 | 09:37 PM
t.ford10's Avatar
Question update
I repaired a loose socket connection on the turn/hzard light. But the marker light is tight, bulb is good, but no power coming to light from harness connection? Any ideas??
Old Feb 22, 2005 | 03:31 PM
CaliE320's Avatar
88 260 E
Blinker relay is going bad, also check your OVP
~Cali
Old Feb 23, 2005 | 01:59 AM
ashman's Avatar
2004 C240, 2015 GL350 Bluetec
is the bulb still fine. sometimes it could be the bulb is staring to go bad and it works sometimes and other times it does.
I've seen it where the bulb looks fine and works then it stops then it works again.
AshMan
