engine wash....
2001 c320 - 2002 ml55 - 2011 c300 - 2014 slk350 - 2015 cla45
engine wash....
anyone here spray down there engine with a hose to clean it?.... thing im worried the most about is getting an area under the hood wet.... that shouldnt be... anyone here have any recommendations on "how to".. areas to avoid.. and products to use?
-thanks
-thanks
W124's
You should degrease the engine, I don't know about watering. If you do though, would be wise to cover up the distrubutor, wires, plugs and all that stuff with a plastic bag of some sort.
1992 300CE AMG Hammer Replica, 2004 C240, 2015 ML350
be very careful with washing your engine, there are lots of electrical items that can get damaged.
I have steam cleaned my engine before, but I took the time to bag up anything electrical I could see and stayed away from anything I was unsure about.
AshMan
AshMan
1 Post
260E , 1989 (for now)
I wash the engine compartment of my car at least once a year. I have always done it when the engine is lukewarm
I usually buy a few spray cans of "Gunk engine wash" and give the engine a very good shower, wait a few minutes and spay-off the stuff with a garden hose at its full pressure setting.
Once done, I re-start the engine and make sure it reaches its normal operating temperature for at least half an hour.
Never had any electrical problem of any sort using this method.
True, my car is still new: 1989 260E with 448,000K on the clock. Maybe when it gets older, it will be a different story.
1991 300ce, 2006 Yamaha Stratoliner
What Jackd said...Go to your local auto parts store and check out what they got. "Gunk" works pretty good but there are others out there. Some require rinsing and some don't. Some require you to actually wipe up the cleaner, others don't. But all, if not most, will tell you to cover/bag all electrical parts and wires. Just find what's best for you.
