remote control
Old Mar 18, 2005 | 11:15 AM
d2Benz's Avatar
2017 GLE350 4MATIC, 2009 ML350 4matic, 2005 4maticWAGON (sold), A Pre-facelift W210(sold)
remote control
Anyone know the lifespan of a remote control...I have the knife like one for a '96 w210....
Mine stop working...changed the battery...worked once...and no more...I tested it by holding down the remote button and NO red flashing...
So I'm thinking its time for a new one from the "STEALER".....
Old Mar 18, 2005 | 09:52 PM
Ben'z's Avatar
E320
I think it might help you save some money and a key.
https://mbworld.org/forums/e-class-w210/99034-case-your-smart-key-broke.html
Old Mar 20, 2005 | 11:12 AM
d2Benz's Avatar
Benchang,
thanks for the info.
Mine is the switch blade.
Is it possible to buy a used remote on ebay and reprogrammed it.
Also, a friend has a remote that he's not using....can I reprogram the remote to work with my car....His is a '96 w210 too.
I'm too additcted to the remote entry....I hate sticking the key inside the whole.
Old Mar 20, 2005 | 11:49 AM
E-Klasse's Avatar
W205 C300
Used ones are no good. They can not be reprogrammed.
Old Mar 20, 2005 | 01:43 PM
Ben'z's Avatar
E320
Sorry I can't answer your questions.
I know that Zam2000 removed his old chip and installed it to the other remove control.
Since the key can't be reprogramed.
Originally Posted by d2Benz
Benchang,
Old Mar 20, 2005 | 02:27 PM
OceanView's Avatar
W212 & W210
What Zam did will not work on a switch blade type key.
Zam has a 98 and his key is different.
You may have to get a new key from the dealer on this one.
Let us know what they charge you.
Good Luck
Old Mar 20, 2005 | 03:28 PM
rob_fed's Avatar
W204 C300 2010
From my understanding the switch blade (key) type is not the same as the newer "SmartKey". From memory, I thought the older type remote "can" interchange with other remotes of the same type. The owners manual had the procedure to program this type. Like everyone else reported, the Smartkey type cannot be reprogrammed from one care to another. The data seems to be hard coded into some sort of read only memory in the Smartkey. This why the Ebay Smartkey modified with the original memory chip worked.
Old Mar 20, 2005 | 09:55 PM
E-Klasse's Avatar
W205 C300
The switch blade keys can not be reprogrammed either. The procedure in the book is for resyncronizing it after the battery is changed. It still has to be the one for the car that it came with.
Old Mar 21, 2005 | 12:14 PM
Peter Guenther's Avatar
92 500sel/01 320e wag
No red light no work, check the contacts to see if they make connection, the remote 0n my 92 went thru the wash. I opened the case dried it out with hair dryer, put in new batteries the red lamp came on, I resynced it works!
Old Mar 24, 2005 | 11:51 PM
d2Benz's Avatar
The verdict is in, couldn't get the remote to work, checked the contacts and even have a mechanic at the benz stealer checked it out....
So I ordered a new remote/key...can't order the remote by itself....$138 + tax.
Old Mar 25, 2005 | 02:33 AM
BenzVince's Avatar
09' E350, 01' Maxima SE, 93 Nissan Maxima SE, 1987 Nissan Maxima SE
Ouch, costing an arm and a leg, cuz I need to get a second key remote since one of my remote got busted when I dropped it.
