E430 Vs E430 4matic
I drove both before deciding on the non-4-matic. Like you I live in the bay area and only occasionally hit snow. Below I've summarized the factors I considered before buying the 2wd version.
* The 2wd's ESP is very good. Through traction control and selective braking it provides an excellent level of stability, safety and the ability to accelerate in many circumstances. When I bought my car I had to road-trip it back through snowy and icy roads in Wyoming and Utah and didn't have a single problem; I will note that I drove pretty much with the conditions in mind, however, and therefore rarely saw the exclamatory warning indicator light up.
* In too many cases the one thing 4wd owners in general often overlook is that 4wd only allows you added traction for acceleration, which means that you can more quickly get to a speed from which you cannot stop or turn safely, i.e., you can get yourself in trouble that much quicker. Turning and braking limits are imposed by physics; the fact that all four wheels are driven won't help you stop any faster. Basically, you may be able to get unstuck without chains if you have 4wd and may be able to start from very icy patches more easily.
* 4-matic means more things to break down and repair.
* I don't run performance tires (which reduce available traction in inclement weather, particularly cold inclement weather, such as sleet, snow and ice).
* 4-matic results in slightly lowered performance and gas mileage.
* Fewer suspension mods possible for 4-matic (mild lowering, staggered tires, etc.).
* I don't spend much time driving on snowy and icy roads and would not venture into a significant snowfall unless there absolutely were no other option. If I still lived in Colorado I might well have gone for the 4-matic, but as well as the 2wd with ESP performed on the drive back, perhaps not.
Basically it comes down to how you weigh out those various factors, any one of which could turn the tide one way or the other. The real trick is to make sure you get maintenance records and if you can get a starmark extended warranty. All the technology in these cars gets very expensive to repair.
Good luck, happy shopping, and enjoy the ride.
Greg
The bigger problem for me is fitting skis into the backseat since the seats don't fold down!
Greg
