Keyless Entry blinking red and green
Old May 6, 2005 | 07:15 PM
persianb28's Avatar
I have an 96 E320 and whenever I use the keyless entry system, the red and green lights start blinking simutaniously for about 20 seconds. The system works fine, but it is the first time i have this blinking light situation. Anyone know whats up?
Old May 6, 2005 | 08:15 PM
lexrex's Avatar
'98 E320 4Matic, '85 380SL
battery low?
I don't know a lot about the older style keyless entry since I have the smartkey system, but maybe it's telling you that your remote battery is low...
Old May 7, 2005 | 02:57 AM
OceanView's Avatar
W212 & W210
yes, it's the battery in the remote.
change it. If you still have the same problem, it could be the battery on the car. Should get it tested if that's the case.
Old May 7, 2005 | 01:28 PM
MugenRD's Avatar
most likely its the battery in the remote.
Same thing happened in my S class.
