Spring Pads
Old Jun 25, 2002 | 05:14 PM
LorinserLV2's Avatar
96´E280 6.cyl
Question Spring Pads
can anyone explain what these are?
Old Jun 27, 2002 | 08:00 PM
RUSSH's Avatar
1995 Oldsmobile Cutlass Ciera
They're rubber buffers that sit between the coil springs and control arms. You can get different thicknesses to lower or raise the heightof the car slightly as long as your tires will let you....
Old Jun 28, 2002 | 09:05 PM
M Brabus's Avatar
97 E420
actually the spring pads sit on the top of the coil spring, not on the bottom (control arm).
for your w210, there are 5 different thickness for the front and 4 for the rear.
Old Jun 30, 2002 | 08:20 PM
96´E280 6.cyl
How can i see which one i´m using?
Old Jun 30, 2002 | 09:19 PM
pocholin's Avatar
Volvo V90 CC
What prices are we talking about for a W210 and how difficult to install are they?
Old Jun 30, 2002 | 10:42 PM
RUSSH's Avatar
I think they have ribs on them..2 ribs is so many mm, 3 ribs are so many mm., etc.
Old Jun 30, 2002 | 11:05 PM
stephens's Avatar
E55, F550, S600 Ducati 999
A set of spring pads should cost less than $25. The problem is you have to take your springs out to install them, so if you are using a shop, you are looking at 2-4hrs shop time for the job.
Old Jun 30, 2002 | 11:33 PM
linh's Avatar
99' SLK 230 & 01' CLK 430
You can tell your spring pads size by using a flash light and look around the bottom edge of the pad to find the "dot". Each dot represent the pad size number (3 dots= pad #3).
Installation with factory spring compressor take about 1 hrs but they usaully say it take about 2-3 hrs so they can charge you $$$$. 3 hrs, that's how long it took me to do spring installation without the spring compressor.
Old Jun 30, 2002 | 11:45 PM
pocholin's Avatar
Volvo V90 CC
Interesting, does the ride become affected by this mod? or just the hight?
I'd like to lower my car, but I don't want it any stiffer, that is why I ask.
Old Jun 30, 2002 | 11:59 PM
stephens's Avatar
Doesn't really effect suspension stiffness, I'm not convinced that H&R spring is actually stiffer than AMG Euro so do not be concerned about H&R making ride too stiff.
Old Jul 1, 2002 | 03:47 PM
M Brabus's Avatar
97 E420
pocholin,
spring pads are not the ideal way to lower your car, it is hardly noticeable. we're talking millimeters, not inches; so will not produce the visual looks of a lowered car.
Old Jul 1, 2002 | 03:52 PM
pocholin's Avatar
Volvo V90 CC
