High Beam Switch
Now my high beam stayed on, even after I turned off the lights....Then I pushed the bushing inside the steering column down and the high beam goes out.
But, this is just a temporary fix...as the black cover is still out of place.
My question is..If I'm able to put the black cover back, will I have full operation again, OR do I need to replace the high beam/wiper/turn-signal switch???
I will try to mess with it in the morning when there is daylight.
H E L P... b4 the high beam comes on by itself and kill my battery....thanks...
I never knew that the high beam will go out as soon as I turned off the ignition....and I've owned this car for a lil' over 2 years...well, I guess I always turn the lights off be4 ignition off, so I never knew...It is a relief to know that the high beam will NOT come on while the car is packed.
still need suggestions
