need help!
Old Aug 14, 2005 | 08:01 AM
samgazawie's Avatar
Exclamation need help!
I have a E430 4matic, I changed the front pads and rotors, new tires and high speed balance but still have vibration around 50 and when I apply the brakes over 40, vibration occurs, does anyone know why?
Old Aug 15, 2005 | 01:47 AM
ghaffar23's Avatar
'08 CL600 with 152k km; '01 E430 4Matic with 433k km; '17 Porsche Cayenne with 130k km
Funny that you should mention that...
I am having the exact same problem. Have you suspected any problems with the transmission? I know mine has been acting funny the first month after I bought my car. I just haven't had time to let my car sit in the shop for an indeterminate amount of time. It is a good thing I bought it CPO, so it has that Starmark warranty for a year. I am taking mine in for a check-up tomorrow...I, myself, have a humming upon disengagement of the accelerator at high speeds and around 15 to 20 MPH. There is a 'clunking' sound coming from the rear end if I let go of the accelerator and quickly re-engage it, especially at low speeds. Hopefully, yours doesn't have the problems mine has...but have the stealership/qualified mechanic look at it.
Old Aug 15, 2005 | 10:25 AM
E320Star's Avatar
2000 E320 Sedan
Re-do tire balance again. and after 500 miles one more time.
Old Aug 15, 2005 | 11:29 AM
richyoung's Avatar
Had a similar problem with my 99 e320, shifting awkward and clunking noises at low speeds. Had the car in for an oil leak and had them check the transmission. The control unit had failed. Leak and transmission repaired under starmark extended warranty.
